Hi there,
I'm really hoping someone can help me out since it's driving me nuts
I have a custom PC which I built 2 years back.
Around 8 months back I started having issues with my GPU and my display
I thought that the issue was with my GPU so I sent it back for warranty and had it replaced.
It came back and I tried again but it has the same issue so I thought that maybe it was a rare occurrence or a coincidence that the replaced GPU had the same issue so I sent it back (a replacement takes a month so this took 2 months)
After another came back that had the same issues, I thought that the issue would be with my MOBO so I took it to a shop
The shop was really confused as well and it ended up horribly (they fried my MOBO, Hard disk and PSU. Dont ask).
The shop did replace the parts so the MOBO and the PSU are new.
Anyway, I brought it back and it has the same issue.
I finally used DDU to remove any drivers and reinstalled it while keeping windows update on pause (as suggested by a YouTuber) and it finally worked for some time.
I went back to my hometown for some time and came back after a period of about 2 months to find that it had the same issue and now the DDU route doesn't seem to work.
Anyway here is the current status.
The display works well when I connect it to my CPU (onboard display). It works well even on my dual display setup
I sent the GPU back for warranty again (The warranty was almost up and the GPU had a small issue with the fans). After getting it back I asked a friend to check it who said there is no problem with the GPU).
now on my PC, after wiping and reinstalling the driver with GPU connected, I get to the windows screen but the screen freezes after about 5 minutes.
I tried a different GPU and the result was the same.
I tried updating the MOBO bios, using old GPU drivers, latest GPU drivers.
Anyway here are my PC specs:
Motherboard:
GPU: ASUS RX 580
RAM: Vengence RGB 16 GB Ram
CPU: Ryzen 2400G
PSU: Thermaltake 550W
MOBO: ASUS ROG Strix B450-F
I'm really hoping someone can help me with this before I go nuts. I think the issue might be from the MOBO setting?? Im not sure though
Motherboard:
GPU: ASUS RX 580
CPU: Ryzen 2400G
