Question Display Issues
Nov 22, 2023
So in a nutshell this whole saga with my pc has been going on for quite some time and im sick of it. Basically whenever im randomly playing ill lose input signal and i hear a windows 11 notification but i cant see it because of the input. If anyone has any idea it would be greatly appreciated cus im stuck...
My specs are
GPU: NVIDIA GeForce RTX 3080
CPU: 11th gen Intel I9-11900KF
RAM: 32 gigs
Btw i brought my pc into a repair shop and they said they had no problems with it and when i brought it home it started again... i have a theory tho for the cause of this. It could be my monitors because i use 2 tvs and the repair shop used 1 monitor... idk tho
You hit the likely nail on the proverbial head.
To begin with, TVs are not monitors, so you can sometimes expect unexpected behaviors from TVs simply because they are not monitors and do not always behave like monitors. There are many differences between monitors and TVs.
Secondly, and especially if they are not identical TVs, you can expect the possibility of even more issues with dissimilar TVs than you can when trying to use monitors that have different resolutions, refresh rates and response times. Everything that is different is always a potential point of trouble.
Try just using one TV and see if you still have the problem. If you do, try just using the other TV. If you still have the same problems when using either of the them individually, then the problem is PROBABLY not due to that but is something else, and that will help to narrow it down a bit. Could even be due to a setting in Nvidia control panel. I've seen many cases where it was something stupid like being set to 1080p instead of "1080p PC". As just one example.
