Question Display not working, fans spinning
minimum
39
Just got the motherboard replaced. When I press the power button the blue light on button doesn't turn on like it usually do. I was facing same problem earlier also and local shop suggested that it was mobo fault. Now sometimes it boots and sometimes it doesn't. If I turn on supply on off again multple times it sometimes boot and then I can reboot it as many times I want and turn off main power too.. BUT when I leave it completely off for sometime, same thing happens thr fans spin, no display, no power button led then I have to turn off supply and on again several times , then it turns on, power button led turns on too.
I wanted to make sure what's the problem psu or mobo? Don't have speaker attached to motherboard for beeps.
minimum
39
Mobo msi b350 pro vdh
Psu cooler master mwe 500
Ez debug cpu and dram led is ON when it doesn't boot properly and power button led is off too..
Sometimes it powers on and off itself.. idk what's happening anymore...
So basically when power button led lits the pc works fine.
