Hello, and thank you for viewing this thread!
First I will describe what I was doing when the device stopped working.
Then I will describe the steps I have taken in an attempt to resolve the issue, with their results.
System Specs
os: Windows 7(64)
Sony Vaio Laptop Model: VPCF126FM (F-series)
GFX Card: Geforce GT 330M
The problem with my display occur'd when I was attempting to update to the latest nvidia driver supported by my graphics card yesterday(12/15/2013). During this installation I had another monitor plugged in via HDMI to VGA. A bit into the installation my screen flickered(like it usually does when you install a new video driver) but when it came back, my resolution was altered to an extremely low quality, and my plug n play ceased to work.
In an attempt to get my native resolution back, I right-clicked my desktop to get into the screen resolution menu. At this point I noticed that the desktop right-click menu was taking atleast 10 seconds to load, and that I could no longer access my nvidia control panel from there. I ignored that for the time being and once I got into adjust my screen resolution, it's native settings were not available anymore. Shown below.
In my first attempt to solve the issue, I decided to delete all my nvidia drivers and remove any excess with Driver Fusion, and perform a new install of nvidia drivers. I booted in safe mode and ran the program multiple times to get rid of any excess. There was a portion from the nvidia display that was stuck and it says I have to upgrade to pro in order to get rid of it. I continued on anyways and it asked for a reboot. After reboot I attempted to install a fresh download of another version of nvidia drivers, with the custom setting to remove other versions of the software. I got the error below.
After more searching of the web, I found another way to make sure all nvidia applications were removed, and that was by removing all of the information from the C:/ Drive and the registry. I could delete everything except the "NVIDIA Corporation" folder from Program Files. I can click to go into this directory, but if I try it chokes up my computer and it becomes very unresponsive. If I try to delete it, it refuses. I get an "error 0x80070091: This directory is not empty". I believe this folder is the root of my problems, but I am not certain.
Finally, I tried a system restore to a week ago. Again, I got denied with this message after reboot:
After spending a bit of time with Nvidia support live chat, I was suggested to make a new user account. Did that, and still nothing. Another thing I tried was going into device manager, deleting the display and re-installing it via manufacturers website. The driver attempts to update every reboot, but I get this error message:
I am here to ask for help, as I am at a loss. I really hope it's something I can fix, because my life is my laptop and I cannot afford another at this time. Thank you for taking your time to help me with this issue.
***UPDATE***
Surfed the Nvidia forums a bit and found they had a NVIDIA Display Uninstaller available here: https://forums.geforce.com/default/topic/550192/geforce-drivers/display-driver-uninstaller-ddu-v9-9-released-12-10-13-/
Used this in safe mode and it detected the display adatapter:
I am still unable to install NVIDIA drivers. 🙁
System Specs
os: Windows 7(64)
***UPDATE***
