Display port cable won't do 144hz at 1440p.
umarcrespo
Commendable
Jul 12, 2016
22
Hello,
So I got this new Display Port cable for super cheap because I needed a long one anyways. I tried Switching to a 144hz on 1440p and the screen went on and off and had lines all over it. I switched the cable and used a shorter dp cable that originally came with the monitor and it worked just fine. I think it is a faulty cable but then again, can all dp cables really run 144hz at 1440p?
Only one review. If you want 4K at 144 Hz, then according to https://en.wikipedia.org/wiki/DisplayPort#1.2 you need a DP cable version 1.4. The shorter cable most likely is version 1.4. Your new cable supports 4K resolution, but that probably is at 60 Hz.
https://uae.souq.com/ae-en/amazonbasics-displayport-to-displayport-cable-10-feet-22892284/i/ Version 1.2 - not good enough.
This cable will work: http://www.club-3d.com/en/detail/2367/displayport_1.4_hbr3_cable_m-m_4m-13.12ft/
https://uae.souq.com/ae-en/star-10-feet-displayport-to-displayport-cable-gold-plated-dp-to-dp-cable-support-4k-resolution-3m-black-23579825/i/
This is the link check it out? The reviews were positive so i thought why not.
