Display port cable
eericc
99
Hi guys,
So I had this problem with my build here's what went on...
Cold boot> please enter setup to recover bios settings. Press F1 to run set up
Also it won't boot causing the Asus anti-surge to act up
I found out what was causing this and it was the display port cable I bought.. I was wondering why would the cable do all of this?
Long story short... DisplayPort has 19 wires but 20 pins. Cheap knock off cables connect pin 20 which is a big no no. Get a displayport certified cable and your cable woes go away.
I can go into detail if you're interested...
Here's a list of all certified cables
http://www.displayport.org/products-database/?products_category%5b%5d=cables-connectors&products_manufacturer=
