First question, what processor are you working with? A bottom of the barrel chipset motherboard(H310) would mean you have can't overclock on the ram or CPU on top of it being a budget chipset, would mean that you would be looking at an aircooler, which is cheap instead of investing on an AIO that is near 2 times the cost of said aircooler(depending on where you're located). I meant you overspent on the cooling.
Secondly, you will need to pass on your full specs like so:
CPU:
CPU cooler:
Motherboard:
Ram:
SSD/HDD:
GPU:
PSU:
Chassis:
OS:
Monitor:
include the age of the PSU apart from it's make and model. BIOS version for your motherboard at this moment of time.
Is it that the motherboard just does not support water cooler at all?
For the sake of relevance, any form of cooling can go onto the motherboard, not just aircooling. I'm assuming the mounting on your motherboard's CPU socket was too tight, relieve some pressure on said CPU mount and see if that helps your system to POST.
If you're able to get to BIOS, set the CHA_FAN header to operate off of the CPU_FAN header, that should mimic the CPU_OPT header on higher end motherboards.
