Display Problem for CRT.
tim78
7
I have a crt Monitor (LG 700E). Recently I upgraded my PC from P4 to i3 4150 with intel 85fl motherboard. The motherboard has no vga port. Should I use a adopter/converter (DVI to VGA). Or I shall have to change the monitor. If the converter/adopter works how would be the display in my old monitor.
If i use a gt610 graphics card will it increase the performance further.
The motherboard has no vga port to connect the crt monitor. What is best option - a converter / a new monitor or a low budget graphics card ?
