display problem, vertical lines appear randomly on screen. HELP newly built pc
ntc321
9
Newly built pc from cyberpower pc (bunch of c*nts before I got the computer, should have seen problems coming) second day into having this computer I was playing BF4 on ultra settings and randomly 15 mins'ish into a game the screen went black with these off black vertical lines, shut computer off, turned it back on. two mins into a new game same thing happens. updated the drivers on my graphics card, give it another try, turn the settings down to high to see if that helps again not two minutes into the game same thing happens but with beige lines. restart computer and trying playing heroes of the storm about 6 mins into the game (ultra settings) same thing happens!! now I'm here freaking out! I have attached screen shots of my specs from speccy also pictures I took of the screen when the problem happen. Someone please help this is very upsetting 🙁
specs: http://imgur.com/SQ1ogg8
Error: http://imgur.com/f8hv5wU,DmYGwwV#0
http://imgur.com/f8hv5wU,DmYGwwV#1
Either blown capacitors, or your mobo and your gpu are having a fight (meaning get a gpu with the same brand as your mobo, or vice versa). Take it back to where you bought it, and exchange it.
(Previous experience: I bought a XFX card and it didnt work, so i got a MSI one and it solved the problem.)
