Display problem with 144hz
Feb 14, 2018
6
In december I've bought a 144hz Monitor, specifically an Acer KG271 and recently I have figured out that I have it locked in windows on 60Hz, so I changed it to 144Hz, but since then an issue is accuring when I'm gaming. It's fine for a while, but soon it seems to lock itself on 48Hz whenever my game is under 144fps. When it's above it's fine. Only way I have found out to fix this issue temporarily is to restart the computer. Also alttabbing out and back into the game fixes the issue but only for a few seconds.
I'll be glad if someone can help me, since I'm experiencing this for a few days and can't find seem to be able to fix this.
Thank you for your answer.
Thanks for your help, but I managed to fix it with turning off AMD freesync. Thank you for your time.
Yeah I did that and changed it to 144Hz that's when the problem started...
