So i just bought a 2700x im using a b350m bazooka mb, i looked on the sight its supports 2nd gen, and i flashed the bios, but i get no display when i turn it on
Any thoughts?
Any thoughts?
I have a 2700xFull system specs? Do you have a graphics card? Is the monitor plugged into that graphics card and not the motherboard?
Are you sure the BIOS was updated successfully? Did you check after flashing it?I have a 2700x
16gb vengeance ram
750 wat evga psu
Rx580 4gb oc
And is is plugged into the gpu onboard wont work, everything works with old cpu which was a ryzen 1400
