Display reboots randomly (HELP!)
Dylan_35
116
6
4,695
Dell monitor randomly reboots, sometimes it happens once and doesn't happen again for a while, and sometimes it happens time after time. I can confirm it is not related to my pc itself. It happened with my old gpu, laptop, and other desktop. I have checked all the connections, used a different dvi cable and power cable yet the problem still persists. HELP! It is not an old monitor, and it does not have a lot of hours on it.
If you haven't done so , I would update the monitor drivers. You have already addressed the usual suspects. I would do the same for the graphics card (just to cover all of the bases).
It may be a defective monitor. If it is still with the return period, that would be the best alternative. After that the best option is warranty repair.
Monitor drivers?
If there is a chance that the electrical circuit is questionable you can use an extension cord to move the monitor to another circuit to test it. If you have access to another system, you can switch monitors (to completely isolate the monitor move only the monitor).
It is by no means a high end panel, it is a Dell IN2030M.
