Display recommendations and help
Redbearz1
34
Hey all,
So I'm rounding off my build and one of my last worries is the monitor, because I'm spending a lot on this build I want a solid monitor that isn't too much, I do intend on buying a 144hz monitor in the future along with a second gtx 970.
Could anyone suggest a monitor? I've been looking at both Samsung S24D390HL and the Asus VX229H, could anyone provide some feedback as to their performance for gaming.
CPU: Intel Core i7-4790K 4.0GHz Quad-Core Processor (£269.94 @ Aria PC)
CPU Cooler: Corsair H100i 77.0 CFM Liquid CPU Cooler (£92.52 @ Aria PC)
Motherboard: Asus MAXIMUS VII HERO ATX LGA1150 Motherboard (£165.56 @ Scan.co.uk)
Memory: Corsair Vengeance Pro 8GB (2 x 4GB) DDR3-1600 Memory (£53.48 @ Amazon UK)
Storage: Kingston HyperX 3K 120GB 2.5" Solid State Drive (£60.58 @ Amazon UK)
Storage: Western Digital Caviar Blue 1TB 3.5" 7200RPM Internal Hard Drive (£42.90 @ Amazon UK)
Video Card: MSI GeForce GTX 970 4GB Twin Frozr V Video Card (£284.34 @ Aria PC)
Case: NZXT H440 (Black/Red) ATX Mid Tower Case (£87.54 @ Aria PC)
Power Supply: EVGA 750W 80+ Gold Certified Fully-Modular ATX Power Supply (£92.34 @ Aria PC)
Operating System: Microsoft Windows 8.1 (OEM) (64-bit) (£76.50 @ Amazon UK)
Monitor: Asus VX238H 23.0" Monitor (£137.80 @ Amazon UK)
Total: £1363.50
(Note i have the monitor selected right now but have heard bad things about it, any possible info regarding that?)
Thanks in advance!
Asus ROG SWIFT PG278Q 144Hz 27.0"
I LOVE this monitor. It is expensive, but it is also a beast! Worth every single dollar I spent, in my opinion. The colors are crisp. The gameplay is smooth. The visuals just melt in your eyes. If you can afford it, BUY THIS MONITOR!
Crisp 27-inch, 2560 x 1440 visuals combined with fast 144Hz refresh rate, 1ms response time, made smooth by NVIDIA G-SYNC technology. This is the goods!
Apologies for the really late reply, kind of lost track of this thread because it wasn't answered for a while. Thank you for your reply first of all, the only one who replied to this thread :).
I'd definitely go for that monitor in a heartbeat but i just can't justify the high cost, thank you for the recommendation. I was however able to up my budget a little and go for the Asus VG248QE 144Hz 24.0" Monitor straight of the bat, it's a little cheaper than the Benq xl2430t that I was planning to buy in the future but is just as highly rated, bar the materials that the benq takes the lead with the metal stand.
Cheers for the reply!
It is a good feeling to know you've helped someone. Have fun :)
