Question Display resets to an unwanted color preset after every 5 minutes.
RedHaze1911
118
4
So im using a tv set for a monitor ( SONY 40WD653) and its hooked up to my PC via HDMI 2.1 and when i set it all up,i noticed that it was too bright for some games and movies,so i changed it to the Warm color scheme instead of Bright. But then it became evident that it wont stay on that color preset and just changes back to bright mode every 5 minutes or so and resets all settings it seems. Ive tried putting it on power saver mode to see if maby it wont override that but it does. So what could be the issue? Its plugged in to a 980Ti gpu. The pc has a 6700k cpu,16gb of ram and two 980Ti GPUs. Any ideas?
tshinhar
100
19
4,595
Nvidia Control Panel
In the pc right click on the desktop and you will see it
From there you can adjust all the display settings: brightness, contrast, color, gama
Just play around with the settings there to your liking
Reactions: RedHaze1911
