Question Display says "HDMI 2 no signal" even though I'm using DP ?
nvidia_loyal
11
I just built my latest PC, but something's wrong with it. There's a yellow diagnostics light under the BOOT letters, and my display is acting very weirdly.
Specs in signature
Specs in signature
Sig space specs can and will change over time. When that happens this thread and any possible suggestions/solution can be rendered moot to the person in the same boat as you're in now.
This is why we ask for people to post with their specs in the thread's body.
Please list the specs to your build like so:
CPU:
CPU cooler:
Motherboard:
Ram:
SSD/HDD:
GPU:
PSU:
Chassis:
OS:
Monitor:
include the age of the PSU apart from it's make and model. BIOS version for your motherboard at this moment of time.
Specs in signature
CPU:
CPU cooler:
Motherboard:
Ram:
SSD/HDD:
GPU:
PSU:
Chassis:
OS:
Monitor:
My specs are CPU: i5 13600K ---- GPU: RTX 4070 Super ---- SSD: SN850X 2TB ---- MOBO: ASUS Prime Z-790 A ---- RAM: G-SKILL Trident Z5 32 Gigabytes 6400 MT/S---- MONITOR: MSI G274QPF-QD ---- PSU: EVGA SUPERNOVA 1000 G6 ---- KEYBOARD: ASUS AZOTH, modded with Akko v3 Cream Blue Pros ---- FANS: ASUS TUF TF120 --- AIO: Deepcool LT720 --- Chassis: NZXT H7 Flow --- No OS yet --- I'm not sure about BIOS model
Have you tried connecting the monitor with the same DisplayPort cable to the DisplayPort on the motherboard?
Check if Auto Detection or Auto Scan is set to OFF in monitor settings.
My monitor isn't turning on, so I can't access the monitor settings, and the DisplayPort cable was already connected to the motherboard.
You can't turn monitor on to access it's settings via the menu system sound like the monitor problem not problem with source or cable.
If available you can test PC and same cable on another display if possible and have the one "that's not turning on" checked by a certified repair place.
Displayport cable has to be connected to graphics card (not motherboard).
You have RTX 4070 Super installed. Don't you?
And you should be able to turn on monitor even, if it is not connected with any video signal cables (DP or HDMI or DVI ).
If monitor says "HDMI 2 no signal" - then it is turned on.
Reactions: satrow
I have connected it to both the GPU and the Mobo, and I will try to turn it on without cables connected.
