Question Display showing no display cable connected error . hlep me plz
Mar 10, 2019
Display not working on motherboard , i m trying to use 2 display , 1 on graphic card and another on mother board . , The mother board screen is black ? help plz.
asus motherboard H61M-CS
intel i5-2400
Gtx 1050ti 4gb
Phillip Corcoran
When you install a graphics card, the integrated GPU is automatically disabled to avoid resource conflicts.
On some motherboards, the BIOS supports using both at the same time by manually making the required changes to the BIOS configuration.
I don't know if your motherboard supports this feature so have a look for yourself.
Alternatively, run both monitors from the GTX 1050 (which is how you are supposed to do it anyhow).
Similar threads
