display will not fit to screen
Lunix89
86
for some reason, my display will not fit to screen with 1980x1080. ive enterd CCC, and clicked on desktop management tab, then creating and arranging desktops, clicked the black triangle, but the only options that gives me is to rotate and identify.
now, in the ccc i have also been to desktop properties, but i can only get the display to fit to screen by going from hdtv to basic, and selecting 1680x1050. but its not a crisp, nice quality display like 1980x1080 is meant to be.
help !
this is what i have
www.pcworld.co.uk/gbuk/desktop-pc-monitors/monitor-projectors/pc-monitors/acer-s240hlbid-full-hd-24-led-monitor-21433233-pdt.html?gclid=CKyxzcyuob4CFdShtAodJkoAVQ&srcid=198&cmpid=ppc~gg~~~Exact&mctag=gg_goog_7904&s_kwcid=AL!3391!3!28126353980!!!g!60595298995!&ef_id=U21gEAAAAe0ttY28:20140510123251:s
there is no such thing as that in the amd ccc. also, i have integrated graphics with my intel cpu, but what im using for my display is a sappire r9 280x toxic.
Go to the video card settings, and choose the resolution you want to use. Why is your card detecting your card as an HDTV as you said in your post? you said you had to change it from hdtv to basic?
both are set to 60hz.
