Display with extended value range? Not sure what to look for.
May 21, 2018
7
Hello,
I was looking for a good budget display. I paint digitally and for me, it is important that the screen shows as many greyscale values as possible. I'm not sure what characteristic should I look for, what I mean is that for example some screen the black is dull, even after correcting the setting. Others (like my smartphone) display correctly the dark values but not the difference in light ones.
What parameter if any represent the range of values a screen displays?
Otherwise, what are some good display for under 200 €? 1920 x 1080 is fine if the color and values quality is better, 24" is more then enough.
Thank you.
I guess contrast is what I´m looking for but I´m not sure wich number is better.
ZOWIE RL2455 24" - 1000:1, (12 000 000:1 dynamisk kontrast)
Samsung 24" S24F350H - 1000:1, (Mega dynamisk kontrast)
AOC 24" G2460VQ6 75Hz - 1000:1, (Dynamisk: 80M:1)
Wich of these is supposed to be better?
