I'm currently designing a new build I will be using (primarily) for Premiere Pro, After Effects and Photoshop editing and production. As there are now a few 4k monitors that accept DP 1.4 cables and the build will include two GTX 1080s, I would like to take advantage of the spec. I have a bit of a stumbling block I need to overcome, however.
My monitors are along one wall (attached to my desk) and the computers are in a conditioned closet behind me. Currently, I run DL-DVI cables under the floor. Looking at the specs for DP 1.4 it appears the max length is less than what it will take to complete my job (~18-19 ft). In reading the spec I see mention of longer lengths if "active" cables are used, but my searches have not been able to find active/extension/repeating/etc cables. Do any of you know of a resource in that regard?
Thanks.
Thanks.
