slawter Dec 6, 2019 15 0 10 Dec 6, 2019 #1 Hi, I own a 1070 GTX and a Dell AW2518HF monitor. My VAG has an 1.4 displayport and my monitor has a 1.2 displayport. Which cable should I buy, the 1.4 or the 1.2 displayport cable?
rgd1101 Don't Moderator Nov 7, 2011 74,864 4,245 176,290 Dec 6, 2019 Solution #2 they are backward compatible. get the highest rated cable you can get Reactions: slawter Upvote 0 Downvote Solution
slawter Dec 6, 2019 15 0 10 Dec 6, 2019 #3 rgd1101 said: they are backward compatible. get the highest rated cable you can get Click to expand... Thank you! I was not quite sure that only the ports are combatipble backwards or the cables too. But now I know that Upvote 0 Downvote
