DisplayPort cable doesn’t go all the way in
redwildboy
9
As the title says, Part of the displayport cable is blocked by the case so it doesnt go all the way in. The monitor works fine though, but it disconnects when inpull it out just a little bit. Is this fine or will it have any affects on the monitor? I dont wanna ruin my monitor.
Thanks
Shouldn't bother the monitor that it looses signal occasionally when you tug on the cable. But I'd fix it anyway. See if you can loosen the gfx card mounting screws and slide the card away from the obstruction a tad. Enough to allow the connector to fully seat.
