I have a gtx 1070 and an asus VG248 QE monitor. My problem is that I have another monitor which only uses DVI or VGA connectors and I must use a Displayport cable with my monitor because that is the only cable which supports 144hz 1080p other than the DVI however my GPU only has one DVI input. The problem lies where if my computer turns off, I still have power to my case LED's however I cannot turn the computer back on without removing the DP cable. My question is, 1)How do I get this to work without having to unplug the DP cable to turn my PC on 2) Is doing this harming my GPU?
Extra info
DP cable is DP 20-pin Male, v1.2 (6 foot) iCAN brand.
Asus P8Z77-V LK
Intel Core I7 3770 non K
Coolermaster hyper 212 Evo
Gigabyte G1 GTX 1070 8 GB
16GB Corsair Vengeance RAM 1600mhz
Samsung 840 EVO 128gb
WD Caviar Black 2TB 7200RPM
EVGA 650W Semi Modular Bronze Power Supply
CM Storm Case
Extra info
Asus P8Z77-V LK
CM Storm Case
