Question DisplayPort issue with Viewsonic monitor ?
i5dude
Monitor: Viewsonic XG2402
GPU: EVGA GTX 1060
Using the above monitor and GPU with a DP connection I'm noticing a strange behavior. If the monitor is powered on AFTER the computer has booted to the Bitlocker screen, then the monitor does not get a signal from the GPU. This does not happen if I use HDMI connection.
I have tried both DP ports on the GPU and changed DP cables using a VESA certified cable, but this did not fix the issue.
Any ideas?
