Hi guys, I'm here to ask for your help to understand what's happening with my displayport connection.
I have always used my Acer Predator X34 G-Sync monitor with Displayport, which allowed me to benefit from G-Sync and the overclock to 100 hz.
But unfortunately, my DP connection has started to give me some problems: it continuously loses signal, making it impossible to use.
Here is a video of the issue: https://youtu.be/OIXNY7O6QBU
Instead, HDMI connection works flawlessly.
I've tried every fix I could find on the forums:
-unplugging and plugging again only solves the problem temporarily, and after some minutes it starts to lose signal again
-I tested if the cable was totally plugged both in my gpu and monitor
-I tried to disable G-Sync
-I tried to reset my monitor
-I tried to reset my mobo BIOS
-I tried to purchase a new DP cable (https://www.amazon.it/AmazonBasics-Cavo-DisplayPort-metri/product-reviews/B01J8S7624/ref=dpx_acr_txt?showViewpoints=1)
-I tried to do a clean installation of my Nvidia drivers
Then I discovered something interesting: I removed my GTX 1070 (Gigabyte G1) and plugged my DP cable into my motherboard (Asus Z170-A) to use my integrated graphic card (Intel i7 6700k)... and I was shocked to see that my DP connection worked flawlessly!
This made me think the problem could be in my GPU. So I borrowed another gpu (a Gtx 1080) from a friend: unfortunately, my monitor gives me the same problem. So I suppose my gpu is not the problem.
Summary:
-Acer Predator X34 DP connection doesn't work when the signal comes from anexternal gpu (GTX 1070 and 1080)
-Acer Predator X34 DP connection works when the signal comes from my integrated gpu (Intel HD Graphics 530)
-Acer Predator X34 HDMI connection works in both cases (with both external and integrated gpu)
What do you think about it?
Is it possible that the monitor DP port has a poor connection and can't handle the gpu signal (but for some reason it can handle the integrated gpu)?
Thank you in advance for your answers![Smile :) :)](/data/assets/smilies/smile.gif)
Summary:
