I have an eVGA 1050Ti SC video card and have two monitors hooked up to it. One monitor I use a DVI cable and a DisplayPort cable for the other. My previous video card had/used two DVI cables.
My monitors have built-in speakers and I have both Audio inputs (monitor menu) selected as Audio-in (NOT DisplayPort - which is the other option). I have the audio output of my motherboard (green connector) connected to both monitors using a left/right splitter cable. This used to work great!
Now that my one monitor is hooked up via DisplayPort, the nVidia drivers want to control the audio to that monitor via that port and not the audio-in jack. My system has the default audio output (playback device) as the speakers. When I do an audio test, I hear it on my left monitor (for the left speaker) and the right (DisplayPort connection) is dead. If I change the audio input source on the monitor to Displayport (monitor menu), it still does not work. However, if I test the audio output device indicated as my monitor, I hear the sound from the DisplayPort connected monitor.
I have tried disabling the nVidia High Definition Audio in the Device Manager, but this did not work either. How do I get both my monitor speakers to work (left and right individually as before) when I have the audio hooked up to both via the audio jack, when one is hooked up via DVI and the other DisplayPort? The DisplayPort is "stealing the audio" for that monitor.
I don't understand why mid-range video card (and others) do not have at least 2 of the same output ports anymore!
Any help would be greatly appreciated!
