That's somewhat common when using a mid-tower case with an SLI setup. Just ensure you have adequate airflow through the case so heat does not build up inside.
I fave 2 Phantek full size fans in the top and a stock case fan. Do you think i should add another?
I think maybe in the front of the case there's room for another fan because i'm not putting any lower drives in, it should hit them directly.
