So I did a short test in Unigine Valley and it seems there are some texture / objects distance issue
If you check the short video I took you can see how objects pop in and out approaching them. This can't be an issue with the Valley test?
I just reinstalled the latest drivers and I am at a loss of what's going on
https://streamable.com/xfri2m
This is basically the Radeon Software Hardware tab with all the details for the GPU. Anyone has a clue what should I be doing for a possible fix, any help please? I think I've noticed the same issue lately in Modern Warfare Warzone but I dissmised as a game issue with reduced distance rendering
GPU - Radeon RX 580 Series - Primary/Discrete
VRAM - 8192 MB - GDDR5 2000 MHz
Graphics Card Manufacturer - Powered by AMD
Graphics Chipset - Radeon RX 580 Series
Device ID - 67DF
Vendor ID - 1002
SubSystem ID - E366
SubSystem Vendor ID - 1DA2
Revision ID - E7
Bus Type - PCI Express 3.0
Current Bus Settings - PCI Express 3.0 x16
BIOS Version - 015.050.002.001
BIOS Part Number - 113-1E3660U-O5R
BIOS Date - 2017/10/19 06:35
Usable Memory Size - 8192 MB
Memory Type - GDDR5
Memory Clock - 2000 MHz
Core Clock - 1411 MHz
Total Memory Bandwidth - 256 GByte/s
Memory Bit Rate - 8.00 Gbps
2D Driver File Path - /REGISTRY/MACHINE/SYSTEM/CurrentControlSet/Control/Class/{4d36e968-e325-11ce-bfc1-08002be10318}/0000
OpenGL® API Version - 4.6
OpenCL™ API Version - 2.0
Device ID - 67DF
Vendor ID - 1002
SubSystem ID - E366
Revision ID - E7
Memory Type - GDDR5
