Question DIY PC Case - RGB Controller
amcdannell2002
5
Ordered a RGB case from DIYPC. Plugged everything in but couldn't find a spot for the "POWER" connector on my motherboard. Leads to the RGB Controller which fans are connected to. On bootup, case fans do not work.
Attached images to thread of the connector.
Is this for a header on my motherboard or for a different kind of PSU?
Male side
Female side
Thanks!
That is a Molex connector.
https://en.wikipedia.org/wiki/Molex_connector#/media/File:Amp_and_Molex_Connectors.jpg
Just connect the Molex Connectors from the Case fans into Molex Connectors from the PSU There is usually one at the end of the SATA cable you used to power your HDDs or SSDs but some PSU's have a dedicated Molex cable with multiple Molex connectors on it..
It does Not connect to your motherboard.
After taking a look, I don't believe my PSU has those connectors. Could you link me to a few power supplies with that connector on it?
