Dlink wifi problem (plz help)
crohamh
So i just did a fresh restart of windows on my computer because i was too lazy to clean it. anyways i installed all the drivers for my gtx 1050ti i also installed the dlink wireless wifi adapter drivers. Before the fresh restart it worked 100% fine always 150+mbps up and down now after the fresh restart the internet quality is bad it keeps dropping and going down do super low speed. can anyone help me???
Yes , if you are lazy than reinstall the windows again and don't install the dlink drivers to your router. Windows installs the newest ones anyway. Try restarting your modem. If it doesn't helps there should be a small hole in the back of it press it for one minute with a pin or pensil.
im talking about the wireless adapapter i put in the pci slot in my computer to give my computer wireless access now for some reason i can beat 10mbps before the fresh restart i had 150+
