.dll problem
G
Guest
Guest
Archived from groups: microsoft.public.windowsxp.security_admin (More info?)
I installed an activeX control at a website and it wrote iasad.dll. This
fill acts like spyware creating icons, changing my home page, and stops every
search engine from working properly. It is a dll file so I am not allowed to
delete it. I was wondering how do I remove this from my computer or
quarintine it so that it will no long affect my pc. Any help would be
appreciated.
Don Gladfelter
Malke
3,000
> This fill acts like spyware creating icons, changing my home page, and
> stops every
> allowed to
> appreciated.
> Don Gladfelter
You invited spyware into your machine and now you need to get rid of it.
Here are general malware removal steps. It is crucial that you do
everything with updated tools in Safe Mode. The reason you cannot
delete the .dll file is because it is in use. That is why you need to
remove malware in Safe Mode, when the programs are not running.
First delete all Temporary and Temporary Internet Files. Then:
1) Scan in Safe Mode with current version (not earlier than 2004)
antivirus using updated definitions.
Before you remove malware, get LSPFix or WinSockFix for XP - see links
below.
2) Remove spyware with Spybot Search & Destroy and Ad-aware. These
programs are free, so use them both since they complement each other.
There is a new version of CWShredder from Intermute. I would not
install the other Intermute programs, however. Alternately, there are
CoolWebSearch malware removal steps at SilentRunners.
Be sure to update these programs before running, and it is a good idea
to do virus/spyware scans in Safe Mode. Make sure you are able to see
all hidden files and extensions (View tab in Folder Options).
If the malware remains even after you used Ad-aware and Spybot, you can
scan with HijackThis. HijackThis is an excellent tool to discover and
disable hijackers, but it requires expert skill. See below for
HijackThis links, including sites where you can post your HJT logs. A
combination of HijackThis and About:Buster works well in removing the
About:Blank homepage hijacker. Again, this is an expert tool and
novices should get help with it.
3) If you are running Windows ME or XP, you should disable/enable System
Restore after the system is clean because malware will be in the
Restore Points. With ME, you must disable System Restore completely.
With XP, you can delete all but the most recent (presumably clean)
System Restore point from the More Options section of Disk Cleanup
(Run>cleanmgr).
4) Make sure you've visited Windows Update and applied all security
patches. Do not install driver updates from Windows Update.
5) Run a firewall.
Links to help with malware:
Software/Methods:
http://www.safer-networking.org - Spybot Search & Destroy
http://www.lavasoftusa.com - Ad-aware
http://www.intermute.com/products/cwshredder.html
http://www.tomcoyote.com/hjt/ - HijackThis
http://www.intermute.com/spysubtract/cwshredder_download.html
http://www.silentrunners.org/sr_cwsremoval.html. - SilentRunners
http://www.cexx.org/lspfix.htm - Repair Winsock 2 settings after
removing spyware
http://www.spychecker.com/program/winsockxpfix.html - WinsockXPFix.exe
HijackThis:
http://www.aumha.org/a/hjttutor.htm - HijackThis tutorial by Jim
Eshelman
http://aumha.net - forums
http://spywarewarrior.com/viewforum.php?f=5 - Spyware Warrior HijackThis
forum
http://www.wilderssecurity.com/
http://forums.tomcoyote.org/
General:
http://aumha.net - look under "Security" for various forums
http://rgharper.mvps.org/cleanit.htm
http://mvps.org/winhelp2002/unwanted.htm
http://www.aumha.org/a/parasite.htm - The Parasite Fight
http://www.spywarewarrior.com/rogue_anti-spyware.htm
Malke
MS-MVP Windows User/Shell
Elephant Boy Computers
www.elephantboycomputers.com
"Don't Panic"
Similar threads
