It's wifi disconnect causes dns errors, not the other way.
Your wifi adapter and router info?
ipconfig /all info will NOT put you in any risk, no one is able to use those info to attack you.
If you say so.
Host Name . . . . . . . . . . . . : DESKTOP-ADD1IHA
Primary Dns Suffix . . . . . . . :
Node Type . . . . . . . . . . . . : Hybrid
IP Routing Enabled. . . . . . . . : No
WINS Proxy Enabled. . . . . . . . : No
DNS Suffix Search List. . . . . . : home
Ethernet adapter Ethernet:
Media State . . . . . . . . . . . : Media disconnected
Connection-specific DNS Suffix . :
Description . . . . . . . . . . . : Realtek PCIe GbE Family Controller
Physical Address. . . . . . . . . : FC-34-97-BA-D0-92
DHCP Enabled. . . . . . . . . . . : Yes
Autoconfiguration Enabled . . . . : Yes
Wireless LAN adapter Local Area Connection* 9:
Description . . . . . . . . . . . : Microsoft Wi-Fi Direct Virtual Adapter
Physical Address. . . . . . . . . : 02-0C-43-90-2F-82
Wireless LAN adapter Local Area Connection* 10:
Description . . . . . . . . . . . : Microsoft Wi-Fi Direct Virtual Adapter #2
Physical Address. . . . . . . . . : 00-0C-43-90-2F-82
Ethernet adapter Ethernet 3:
Description . . . . . . . . . . . : NW TAP-Win32 Adapter V9.21
Physical Address. . . . . . . . . : 00-FF-5F-10-22-F5
Wireless LAN adapter WiFi:
Connection-specific DNS Suffix . : home
Description . . . . . . . . . . . : Realtek 8811CU Wireless LAN 802.11ac USB NIC
IPv4 Address. . . . . . . . . . . : 192.168.1.138(Preferred)
Subnet Mask . . . . . . . . . . . : 255.255.255.0
Lease Obtained. . . . . . . . . . : 25 July 2025 2:07:07 PM
Lease Expires . . . . . . . . . . : 26 July 2025 2:09:13 PM
Default Gateway . . . . . . . . . : 192.168.1.254
DHCP Server . . . . . . . . . . . : 192.168.1.254
DNS Servers . . . . . . . . . . . : 1.1.1.1
1.0.0.1
NetBIOS over Tcpip. . . . . . . . : Enabled
