G
Guest
Guest
Archived from groups: microsoft.public.win2000.dns (More info?)
Hello, if anyone could help I'd be most appreciative. I'll try to make
this simple.
ISSUE: PDC and BDC are not synchronizing their Active Directory user
accounts.
DATA: The PDC, a Windows 2000 SP4 server, which primarily acts as a
data and print server had not received any updates in 1.5 years.
Someone decided to update the server which included all of these
updates. On reboot the computer hung on "Perparing network
connections...". A repair installation (overtop) was installed and now
the server allows you to log in. The BDC (Also WIN 2000 SP4 Server)
gives error messages regarding it's inability to find the GC (Global
Catalog). The BDC is primarily a Terminal Server and a software
package that resides on the Terminal Server which requires users having
at least Power User rights will not work unless you are logged in as
the administrator on the Terminal Server. If you try to add any groups
of users or individual users to Administrators you receive messages
regarding the the inability to find the Global Catalog.
IDEAS: Can I demote the PDC (which was the one that received the
updates), effectively turning the BDC into the new PDC?
Thanks in advance!
this simple.
accounts.
Thanks in advance!
