DNS problem
G
Guest
Guest
Archived from groups: microsoft.public.win2000.dns (More info?)
Hi,
I'm having the following warning poping un every 2 hours on my 2 DCs.
I would like to know if any of you seen this before.
Event Type: Warning
Event Source: NETLOGON
Event Category: None
Event ID: 5781
Date: 7/8/2004
Time: 9:35:28 AM
User: N/A
Computer: servername
Description:
Dynamic registration or deregistration of one or more DNS records failed
because no DNS servers are available.
I've found some doc about the ID5781 but none are applicable. Maybe there is
more that i didn't find though.
Thanks!
G
Guest
Guest
In news:u6DBvePZEHA.644@tk2msftngp13.phx.gbl,
Michel B. <mbruyere.nospam@ezemcanada.com> posted a question
Then Kevin replied below:
> Hi,
> hours on my 2 DCs.
> Event Type: Warning
> Event ID: 5781
> Date: 7/8/2004
> Time: 9:35:28 AM
> User: N/A
> Description:
> records failed because no DNS servers are available.
> applicable. Maybe there is more that i didn't find though.
Usually 5781s can be traced back to single-label domain names, which
starting with Win2kSP4 caused errors in DNS, if you have recently installed
SP4 I would suspect your domain is Single-label. The problem is not SP4 but
your domain name, Microsoft had to fix the bug with single-label queries and
registration requests going to the root servers.
In order to acurately diagnose you 5781 you should post your AD domain name,
ipconfig /all, and list your AD zone name in DNS
Best regards,
Kevin D4 Dad Goodknecht Sr. [MVP]
Hope This Helps
When responding to posts, please "Reply to Group" via your
newsreader so that others may learn and benefit from your
issue. To respond directly to me remove the nospam. from my
email. ==========================================
http://www.lonestaramerica.com/
Use Outlook Express?... Get OE_Quotefix:
It will strip signature out and more
http://home.in.tum.de/~jain/software/oe-quotefix/
Keep a back up of your OE settings and folders with
OEBackup:
http://www.oehelp.com/OEBackup/Default.aspx
G
Guest
Guest
Michel B. <mbruyere.nospam@ezemcanada.com> asked for help and I offered my
suggestions below:
> Hi,
> DCs.
> Event Type: Warning
> Event ID: 5781
> Date: 7/8/2004
> Time: 9:35:28 AM
> User: N/A
> Description:
> Thanks!
If you can provide some specific config info on your part, it would help us
diagnose this for your system, such as:
1. Unedited ipconfig /all (from two of your DCs)
2. The actual AD DNS domain name (as ADUC shows it)
Thanks
Regards,
Ace
Please direct all replies ONLY to the Microsoft public newsgroups
so all can benefit.
This posting is provided "AS-IS" with no warranties or guarantees
and confers no rights.
Ace Fekay, MCSE 2000, MCSE+I, MCSA, MCT, MVP
Microsoft Windows MVP - Active Directory
HAM AND EGGS: A day's work for a chicken;
A lifetime commitment for a pig.
G
Guest
Guest
Hi,
You guys pointed right to the point I think. I effetivlely have a single
domain name.
I 'va found a paper talking about what you said, it KB300684
does this could resolve my issue?
Thanks
"Kevin D. Goodknecht Sr. [MVP]" <admin@nospam.WFTX.US> wrote in message
news:OZ3I3nPZEHA.644@tk2msftngp13.phx.gbl...
> > Hi,
> > hours on my 2 DCs.
> > Event Type: Warning
> > Event ID: 5781
> > Date: 7/8/2004
> > Time: 9:35:28 AM
> > User: N/A
> > Description:
installed
but
and
name,
> Best regards,
> Hope This Helps
> OEBackup:
G
Guest
Guest
In news:OLlDdPQZEHA.2016@TK2MSFTNGP09.phx.gbl,
> Hi,
> effetivlely have a single domain name.
> KB300684
This will stop your 5781 events, you always have an issue with the
single-label domain name.
You may still have problems with GPOs getting applied.
Best regards,
Hope This Helps
OEBackup:
G
Guest
Guest
In news:O5E53bUZEHA.3432@TK2MSFTNGP10.phx.gbl,
Kevin D. Goodknecht Sr. [MVP] <admin@nospam.WFTX.US> asked for help and I
offered my suggestions below:
>> Hi,
>> KB300684
And DFS if planning on using it.
Regards,
Ace
so all can benefit.
G
Guest
Guest
In news:%23uOVFhVZEHA.2488@tk2msftngp13.phx.gbl,
Ace Fekay [MVP] <PleaseSubstituteMyActualFirstName&LastNameHere@hotmail.com>
posted a question
Forgot to mention that, BTW you don't have to plan on using it, you have to
use it. The SYSVOL share is a DFS share.
Best regards,
Hope This Helps
OEBackup:
G
Guest
Guest
In news:uVM8pqVZEHA.3716@TK2MSFTNGP11.phx.gbl,
> have to use it. The SYSVOL share is a DFS share.
I was thinking more on if planning on a DFS Root.
Regards,
Ace
so all can benefit.
G
Guest
Guest
so you guys are telling that i'd have to rename my domain one day or
another, right?
is there documents that talks about this and the impacts it can have? we are
somewhat big and can't afford to go down for awhile.
Thanks
"Ace Fekay [MVP]"
<PleaseSubstituteMyActualFirstName&LastNameHere@hotmail.com> wrote in
message news:%23uOVFhVZEHA.2488@tk2msftngp13.phx.gbl...
> >> Hi,
> >> KB300684
> Regards,
> Ace
> so all can benefit.
G
Guest
Guest
In news:%23PVf5JbZEHA.3016@tk2msftngp13.phx.gbl,
> one day or another, right?
> it can have? we are somewhat big and can't afford to go
> down for awhile.
Unfortunately, you can't rename a Win2k domain, but you can rename a Win2k3
domain.
In your situation, your best option is to build a parallel domain and use
ADMT to migrate all domain accounts.
Best regards,
Hope This Helps
OEBackup:
G
Guest
Guest
Win2k3
> domain.
We have a monster problem doing this, we have a databse that is using
information like
domainename\username... and guess qhat... it's an ERP system ;/
G
Guest
Guest
In news:uJ46SscZEHA.996@TK2MSFTNGP12.phx.gbl,
>> can rename a Win2k3 domain.
>> parallel domain and use ADMT to migrate all domain
>> accounts.
> that is using information like
> system ;/
You're kinda stuck with your single-label domain unless you upgrade to
Win2k3 and perform a domain rename operation because you can't migrate
without trust and you can't trust two domains with the same NetBIOS name.
Best regards,
Hope This Helps
OEBackup:
G
Guest
Guest
suggestions below:
>> Win2k3 domain.
>> and use ADMT to migrate all domain accounts.
> information like
I agree your best bet is to upgrade to W2k3 in order to facilitate a rename
operation. Single label names are problematic and difficult to work with
with DNS, which affects AD substantially.
Heres'a a little tidbit from a conversation between myself and a Microsoft
engineer last year concerning this. There's more if you want. I need to dig
it up.
Ace Fekay [MVP] wrote:
>> problem. DNS does not play well with single label names since a
>> single label name does not depict any sort of hierarchy, since DNS
>> is hierarchal based from the leaf nodes (such as "domainname) to the
>> next level (such as "com") to the top of the tree (the dot). DNS
>> cannot handle single label names, hence the issues revolving around
>> it.
Michael Snyder [MSFT] wrote:
> Ace, just a quick comment regarding your explanation below:
> Registration of single label names resulted in registration attempts
> hitting the root servers from so many mis-configured networks on the
> internet that a report on W2k prior to SP4 indicated that Windows
> DDNS updates were responsible for a significant portion of traffic to
> the root servers. To be better internet citizens, W2k3, XP, and W2k
> after SP4 stopped attempting DDNS updates on single label names by
> default.
> The recommendation to avoid single label names is simply a
> recommendation to be a good internet citizen. The system can handle
> single label names, but we highly encourage users to avoid using them
> because it is too easy for users to create problems for themselves
> and others when they use single label names and later want to
> interoperate with other organizations over the internet.
> "> Depends on your scenario. If all part of the same AD domain, yes.
> If not, no
Regards,
Ace
so all can benefit.
Ace Fekay, MCSE 2003 & 2000, MCSA 2003 & 2000, MCSE+I, MCT, MVP
G
Guest
Guest
Hi,
Thanks guys, sorry for the delay to get back to you, i was in a
hurry ;)
You both may have given me enough ammunition to get the management to move
on to win2k3 (which i wanted for awhile, but couldn't).
Thanks i'll print the thread and present it to my manager.
"Ace Fekay [MVP]"
message news:eyYaCXoZEHA.524@TK2MSFTNGP09.phx.gbl...
> suggestions below:
> >> Win2k3 domain.
> > information like
rename
dig
> it up.
> >> it.
> > default.
> > If not, no
> Regards,
> Ace
> so all can benefit.
G
Guest
Guest
In news:OonZYwdaEHA.2520@TK2MSFTNGP12.phx.gbl,
suggestions below:
> Hi,
> a hurry ;)
> move on to win2k3 (which i wanted for awhile, but couldn't).
Good luck. I have more on this subject with multiple threads pasted into one
post from the past. If interested, let me know. I'll post it.
Regards,
Ace
so all can benefit.
