Do 1 KVA UPS good for 750 watt PSU ?
jai360
74
ok guys im gonna build new PC soon
And the PSU im gonna use is Cool master or Corsair 750 watt PSU
i am from india here in my town Power shut down happens frequently so i need a UPS to save the working content and shut down PC safely no worrries about backup time.
my current PC is old one and i use 600 VA UPS it restarts my PC during power shutdown
so it almost crashed my harddrive so i dont want such thing to happen to my new PC
Do 1KVA ups good enough for 750 watt PSU
and heres my new PC specification
AMD FX 8350
Asus M5A99FX PRO R2.0
Corsair TX750 V2
Dell S2240L 21.5 inch
Sapphire AMD/ATI Dual-X R9 280X
Corsair 8 GB DDR3
Seagate 1TB Sata Drive
Cooler Master K380 CPU Cabinet
so plse do help me to brothers :)
Hi
It is highly unlikely that your PC & Graphics cards draw anything near maximum power of PSU except when gaming
The 1k VA UPS is ok for a 750W PSU
modern PSU with power factor correction & high efficiency are even better
The problem is how long the battery lasts before it gets replaced and quality of UPS
if your UPS has a self test mode and it says replace battery dont ignore warning.
I had a cheap UPS which after a few years the battery leaked acid on the carpet
So I went with APC (which is usually considered a good brand)
regards
Mike Barnes
It depends of UPS efficiency, but most common output for 1kVA is 600W (better find out what actual output is in Wats). In worst scenario your GPU (250W)+CPU(125W)+mobo(50W) will drain ~530W (425W nett/0,8) from the plug so its too close to be used on PC's full load.
