Do 4 Way SLI Bridge Connector can be use for 2 Way SLI ?
auzan
8
Hello,
I have 2x Nvidia 500 series graphics (same brand and same series).
I also have one 4 Way SLI Bridge Connector.
But my graphics card only have one finger port connection for each graphics. Before that, this is my graphics arrangement.
My graphics arrangement
500 Series (PCI-E 16x)
skip (PCI-E 8x)
500 series (PCI-E 16x)
skip (PCI-E 8x)
| -------------| (Top)
| --------------| (Buttom)
The question is, do 4 Way SLI Bridge Connector can be use for 2 way sli ?
Does SLI is enabled?
Thanks, Im appreciate the answers.
Hmmm...well, I never tried doing that personally (using Quad-SLI bridge for just a Dual GPU setup), but I think it would work just fine if you plug first and second GPU in the first and third SLI/PCI-e slot respectively. Try it anyway, if it won't work at least you'll know for sure. It's not like your GPUs would explode if it won't work, ya know...%)
