Do all these parts work together + compatible motherboard?
ajunner
15
Hello,
Do all these parts work together? I am worried that the GPU won't have enough power and a 6 pin pcie connector for even more power. Could you recommend me a cheap yet good quality motherboard that can ship to Australia?
GPU: SAPPHIRE R7 260X 2GB GDDR5 OC; 1150Mhz/6600Mhz DVI/HDMI/DP
CPU: AMD Athlon Multi Core Processor AD760KWOHLBOX, 760K Richland 3.8GHz Socket FM2 100W
RAM: Crucial Ballistix Sport 8GB Kit (4GBx2) DDR3 1600 MT/s (PC3-12800) CL9 @1.5V UDIMM 240-Pin Memory BLS2CP4G3D1609DS1S00
HDD: WD Blue 1 TB Desktop Hard Drive: 3.5 Inch, 7200 RPM, SATA 6 Gb/s, 64 MB Cache - WD10EZEX
CASE: Rosewill Micro-ATX Mini Tower Computer Case with Dual USB 3.0, Dual Fans and 12.5-Inch Card LINE-M Black (comes with 2 fans)
POWER SUPPLY: Corsair VS550 550W ATX Power Supply
A few things:
1. I suggest using the pcpartpicker site, in the upper right corner is a drop down window to select your country (Australia) and using it to select your parts, it has auto-detection that will warn you of incompatibilities.
2. Since you are getting a micro-ATX case, you will need to get a micro-ATX motherboard (or it's possible the case may allow mini-ITX motherboards as well).
3. Knowing your overall budget would help, as well as knowing if any other parts will be required (Keyboard, mouse, monitor, speakers, headphones, optical drive, OS, etc.)
A few things:
