swapped cases.
discovered old case had the white wire (never checked black wire) soldered to the case.
so no wifi/BT atm (dont want the antenna sticking out back that is why i like the internal wire antennas).
Asking for safety. (dont wanna not have em connected and risk it being bad and damaging my parts)
could I just cut wire by where soldered then (electrical) tape the wires to the newer metal case?
or do they need connected to metal/plastic/anything in first place? (i only use it for BT and case is only 3-4 ft from me so i dont need large range if that is why they are so long)
