Do Case temperatures need to be adjusted
jazgreen99
95
Hi all
I just would like to find out if I need to adjust my cpu fan speed and my chassis fans? My cpu temperature is 50 degrees centigrade and my motherboard is at 37 degrees centigrade.
Cpu fan-1264rpm
Chassis fan 1-1053rpm
Chassis fan 2-700rpm
Chassis fan 3- 983 rpm
I have a
amd ryzen 3 220g
Asus B450 mb
Xfx 570 rx gpu
Hello, if they came with the case they are probably placed on the right locations where is needed
defined speed of the fan for example fan on the top of the case spins faster or slower than a fan on the back of the case. So i don't think its necessary to change the speed leave them unadjusted. If you have overclocked your GPU or CPU then i dont know maybe only then you need to make them faster but for now leave them like that i think who created the case thought about that before you.
