I'm leaning towards this (see title) being a stupid question so my preliminary answer is that GPU's only consume as much power as they need even when in game. I would be grateful if someone else confirmed this though.
I am running 1020p and got suckered into getting an overkill ASUS Radeon R9 290 4GB DirectCU II OC GPU (not 290x). This GPU is normally made for higher resolutions however I purchased this with future proofing in mind.
The issue i'm having is this:
The ASUS Radeon R9 290 is power hungry (some reviews claim it nears the 400W mark at max output). The GPU box itself says that one needs a MINIMUM 750 Watt PSU. I have a EVGA Supernova G2 850W PSU. Normally I would feel safe, however I bought into 2011-v3. As some of you may know, CPU's for 2011-v3's are considerably more power hungry than their predecessors (140 watt TDP). Following are my specs:
I am not sure if this is a safe setup: I'll be playing Battlefield 4 and Alien Isolation on highest settings, however on 1080p. Again i'm gambling that since the GPU will not run at full capacity to render 60fps on 1080p, therefore, the power consumption should not hit anywhere near the maximum that it can normally consume.
Can anyone confirm this?
GPU: ASUS Radeon R9 290 4GB DirectCU II OC (R9290-DC2OC-4GD5)
MOBO: ASUS X99-DELUXE
CPU: Intel Core i7-5820K, Socket-LGA2011-3
RAM : 4x Crucial Ballistix DDR4-2400 SP QC - 16GB
HD: Seagate Barracuda 2TB
PSU: EVGA Supernova G2 850W
CASE: NZXT Phantom 410
HSF: Noctua NH-U12S
