Do hard drives need active cooling? Does it shorten a hard drive's life span if they do not have fans blowing on them?
LimitedWard,
If HDD's needed active cooling then the world of watercooling would have been flooded with waterblocks for hard drives. In short,
no, you don't need active cooling and the long answer would be; The corsair Air 240 has the HDD's tray mounted in a such a way that all drives in the caddy are vertically placed - that would allow for passive heat dissipation (based on the stack effect) and the warm air would naturally be ventilated through the back via the meshed/perforated rear HDD cover.
For the second part of your question,
having a fan blowing on the HDD doesn't ensure longevity. You have drive activity and platter wear and tear to consider (the amount of data read/write performed on a daily basis as well as its operating periods) and most often a harddrive
can and
will malfunction (at any given period even though brand new) as it is a mechanical device. In terms of engineering, moving parts = failure points
Unless you have WD Velociraptor Drives (which have a heat spreader of their own for said drives insane rpm's) you have nothing to worry about and this eventually will lead me to ask - what sort of drives do you have? 5400, 5900, 7200, 10000 or 15000 rpm drives?
