Question Do I choose the Lian Li O11D EVO RGB or the NZXT H9 FLOW?
raccoon1
17
Guys, I'm building a PC. This is the build. I have almost all the parts except the power supply, which is about to arrive. I'm looking for a case and I came across the Lian Li O11D EVO RGB and the NZXT H9 FLOW. Both won me over because they have a lot of space for VGA and good airflow. I don't know which one to choose. Can you help me by giving me some advice? If someone can answer me and also check if the parts of the build are compatible like with the power supply, I'd appreciate it and I won't forget to give a thumbs up. Thanks and sorry for anything, I'm just being careful.
You have a near similar thread here;
albeit just missing the Lian-Li and the other NZXT case suggestions. The case is actually a personal preference, IMHO meaning you should decide which case to pick out of the two.
No matter what we say, you're going to have to live with the case purchase.
If I were you, I'd wait for the PSU to arrive, then hook up the connectors and see how much space the PSU actually needs while all harnesses are hooked up.
Reactions: raccoon1
