Do i have enough power?
Dragonblids
91
Is a Energon EPS-750W Enought for
AMD FX-9590, OC to 5 GHz
16 GB Corsair vengance 2400 MHz
Asus Crosshair V Formula-Z
Asus Matrix HD9770 matrix
OCZ Agility 3 AGT3-25SAT3-60G
465GB Seagate ST500DM002-1BD142
No it's not enough and it's poor quality.
Your choices for the 9590:
ASRock 990FX Extreme9
Asus M5A99FX PRO R2.0
Asus Sabertooth 990FX R2.0
Gigabyte GA-990FXA-UD3
Gigabyte GA-990FXA-UD5
Gigabyte GA-990FXA-UD7
MSI 990FXA-GD80V2
AMD.COM
Warning: This power draw of this CPU is almost twice that of the average CPU. Due to this, AMD recommends using at minimum a 1000W power supply. For cooling, AMD recommends using either either closed loop liquid cooling or full system liquid cooling.
I asked for PSU, not motherboards?
And BTW i wrote i had the Asus Crosshair V formula-Z
I know that , read the bold print that's why I posted the AMD advice.
What power supply would you then recomment? since the brand matters alot!
