[SOLVED] Do I have enough Rgb headers on the MSI B550 A-Pro to connect 3 RGB Fans?
Your mothertboard has
  • 1x 4-pin RGB LED connector
  • 2x 3-pin RAINBOW LED connectors
Your case has
Onboard button on the RGB Controller or via the Reset Switch (1x 1-to-3 RGB Splitter Cable Included)
If you want to use your motherboard then the rgb has to be compatible with the motherboard.
If you want to use your case controller then the fans need to be compatible with the controller.
Your case has
