do i need 2400 mhz or 2666mhz of ram?
alex.k1.douglas
11
hi wonder if i need 8gb ram with 2666mhz or 2400mhz the 2400mhz is cheaper,
the pc spec is Cooler Master B500 battery AMD Ryzen 5 1600 Prosessor ASUS EX-A320M-GAMING motherboard 8 gb ram ZOTAC GeForce GTX 1060 3GB 240 gb ssd and 1 tb hdd i want to run pubg on 60 fps on medium grafics on 1080p
Ryzen works better with faster RAM. AMD recommends 2666mhz and above, so running 2400mhz wont give you very good performance. 3000/3200mhz are the sweet spot... https://www.toptengamer.com/best-ram-amd-ryzen-5-7-cpu/
