[SOLVED] Do I need a bolster with a Quadro RTX 5000 ?
Sig_Dude
54
I'm about to install a PNY Quadro RTX 5000 into an MSI Tomahawk Z690 DDR 4 motherboard.
Do I need a bolster for this setup?
Thanks for any replies.
I'd say: No.
You have blower-style GPU, without heavy heatsink, as open air styles GPUs would have it, making them heavier and maybe needing GPU bolster. But since your blower-style GPU weighs less than open air styles GPUs, i don't think there's a need for GPU support.
Though, if there may be a small sag and that annoys your eye, then sure, for your own peace of mind, you can get GPU support.
I'd say: No.
I'd say: No.
Thanks for the reply.
Since I'm not going to be transporting this PC frequently (or ever, really), I think I'll just cut a piece of 3/4" wooden dowel to the exact length and use it as a bolster.
Reactions: Aeacus
