[SOLVED] Do i need a cooler for my amd build?
Feb 8, 2019
14
CPU: R5 2600
GPU: XFX Raedon RX 590
RAM: 2X8GB 3400MHZ
MOBO:?
SSD: Silicon power a55 1tb
PSU: EVGA 500W Bronze 80+
Cooler:?
suggest a good mobo for 3400mhz under 150 usd. Do i need a cooling system for this graphic card? Will the stock cooler of the processor be good? I neither render nor overclock
Cooler is not needed, as your R2600 comes with one.
No, you don't need a separate cooler for GPU. It has it's own too. Getting 3200mhz ram will do just as well as 3400mhz. You should choose the mobo first, then select the ram based compatibility with your mobo, instead of getting ram, and figuring out which mobo it will work on.
