Do I need a CPU aftermarket cooler for this?
mikezomfg
20
Hi.
I am getting a AMD FX6300 Black Edition 6 Core (http://www.amazon.co.uk/AMD-FX6300-Edition-4-1GHz-Socket/dp/B009O7YORK/ref=pd_bxgy_computers_text_y) and I live in a very warm climate (http://www.cyprus-weather.com/cyprus-average-temperatures.html) so i'm wondering if I need a aftermarket CPU cooler. I am also getting a Fractal Design Define R4 case, so i'll have the fans that come with them. Do I need a CPU aftermarket cooler?
Thanks in advance.
Yes mate - its the best price/performance cooler around.
Its a little overkill for a 6300 but will give you near silent computing with the r4 case (good choice BTW - its one if the best cases around IMO).
The 212 does require a bit more time fitting bit it is worth it.
The 6300 cooler is in short 'crap' mate & noisy
You don't need to spend much ,this cheap zalman does the job
Zalman CNPS5X Performa CPU Fan for 1155/1156/775/AM2/AM2+/AM3/940/939/754 Sockets www.amazon.co.uk/dp/B006344OMM/ref=cm_sw_r_awd_pkBNub1257MF1
Thanks, I think i'll go with that one. Should I run into any problems of it being overkill?
Great, thanks for the answer! Ordering parts now.
