Do i need a CPU Cooler with these parts?
Annyeong
22
Hello can anybody suggest me a CPU Cooler if i need one?
And by the way i will have 2 monitors including the one in the parts.
Specification:
CPU Intel Core i5-4690K 3.5GHz Quad-Core
Motherboard Asus Z97-A ATX LGA1150
Memory Crucial Ballistix Sport XT 8GB (2 x 4GB) DDR3-1600
Storage Western Digital Caviar Blue 1TB 3.5" 7200RPM
Video Card MSI GeForce GTX 970 4GB Twin Frozr V
Case Corsair Carbide Series 300R Windowed ATX Mid Tower
Power Supply XFX 550W ATX12V / EPS12V
Optical Drive Lite-On iHAS124-04 DVD/CD Writer
Operating System Microsoft Windows 8.1 (OEM) (64-bit)
Monitor BenQ GL2460HM
yes, you need at least a cooler master hyper 212 evo. you could use the stock intel cooler, but you wont be able to overclock.
nice system, it deserves a good cooler. if you have the bucks to spare, get a noctua nh-d14.
Thanks for the reply and for the help!
might want to get at least a 212 EVO.
something considerably better: Scythe Mugen 4
then, there are coolers such as Noctua NH-U14S
then, the heavy weights such as Noctua D14, D15, Silver Arrow, Phanteks, etc.
then there are water coolers such as Kraken X61, Swiftech H240-X etc.
Which CPU Cooler do you guys recommend me buying?
Thanks for the help.
the phanteks 140mm wont fit in the 300r. i personally feel that the $65 noctua or phanteks is the limit since spending $100 on a 240mm aio water unit only afford you at best 0.2ghz higher overclock. its quite a bit of $$$ to justify a barely noticeable cpu frequency bump, and it wont do anything for gaming performance. i would stop at the 140mm noc/teks cpu cooler and spend the extra on a couple noctua 120mm case fans to pull cold air in to keep the gpu happy.
Thanks for the help!
I think ill go for the Scythe Mugen 4
Have a nice day.
