Do I need a CPU cooler?
Hugzie
64
I am looking to build this bad girl right here.
http://pcpartpicker.com/p/2mRgF
I do not intend to overclock at all. So will the stock CPU cooler be sufficent? or should I spend the extra money just in case?
As a side note I will be using this for gaming at 1920x1080.
Ok I clicked anyway :)
Yes the stock cooler will be fine @ stock speeds. It's just a bit loud. You don't need a Z77 motherboard though. You could save money and get a B75 if you're not going to overclock.
Any time you don't plan on overclocking, the stock cooler provided with CPUs will be sufficient. Whether you are tolerant of its sonic profile is another matter. I personally dislike the droning of stock Intel heatsinks compared to the quiet Cougar fans I use on all aftermarket coolers I purchase.
