Case: Corsair carbide air 740
Mobo: Gigabyte AORUS GA-Z370 AORUS Gaming 7
CPU: Intel i7-8700k
GPU: ASUS ROG Strix GeForce GTX 1080 Ti OC
PSU: Corsair HX1000
RAM: G.Skill Trident Z RGB F4-3200C14D-16GTZR 16GB (2x8GB) 3200MHz DDR4
Sound: Creative Sound BlasterX AE-5
So I was originally going to have the Noctua NH-U14S cpu cooler, but the heatsink is MASSIVE and I really don't like the color going on. Considering most of the components in this build are going to be throwing an RGB rave party light show I may as well make an effort to making the inside look nice, which I think a massive heat sink will conflict with this.
Asides from the aesthetics I want the best cooling performance available for my CPU and GPU, I was considering an AIO Kraken X62 for the cpu and letting the GPU do its own thing, but I am considering getting a second card and running sli in the future.
The problem with this is that the 1080 ti run at core temp of 84c and I am worried the bottom card will just be blowing hot air up into the top card, I could see this creating issues down the line and am considering just building a custom loop to start with. I have no experience in this field though and am quite anxious about the whole idea, no matter how much I research into it, I am still paranoid about leaks.
Do you think the two hot graphics cards so close to each other would cause a problem? Do you think I would need a custom loop? Thanks in advance
CPU: Intel i7-8700k
PSU: Corsair HX1000
